DsPIC Block/CAN Configuration
When using either a CAN receive block or a CAN Transmit block, this block configure the mode and the CAN BUS parameters.
Num CAN
Mode
- Normal : the one you will use in most case.
- Loop back : Allow to test the CAN peripheral and the CAN blockset. In this mode, no external connection nor driver are necessary to make the CAN peripheral working. The dsPIC will write and read its own CAN messages.
- Listen only : makes the microcontrolleur able to listen to the can BUS without writting anything. This mode will use only the Transmit PIN of the CAN peripheral The receve PIN can be used for another purpose.
Theses parameters configure the Timing of the CAN bus. Refere to the CAN doccumentation for more informations.
- TRefCAN
- BaudRate
- Progagation Time Segment bits
- Phase Buffer Segment 1
- Sample of the CAN bus line
- Phase Buffer Segment 2
Information, give the clock frequency Fscl of the I2C bus
