DsPIC Block/CAN Receive
Read data from a CAN bus
- 1 Dialog Box Parameters
- 1.1 Num CAN
- 1.3 Message x Data Length
- 1.4 Acceptance Filter x
- 1.5 Acceptance Filter type
- 1.7 Output Flag New Message
- 1.8 Output Identifier
- 1.10 Receive Error Counter
- 1.11 Output Flag Data Lost
- 1.12 Sample Time
- 1.14 Info
Num CAN
Acceptance Filter x
- Standard or Extended
- Standard 11 bits
- Extended 29 bits
Output Identifier
Information
