Release Notes
Revision as of 22:59, 3 January 2011 by LubinKerhuel (talk | contribs)
  • Next release: v3.4b
    • Power save mode (IDLE): timer 2,3,4,5... did not reacts properly in idle mode, making any peripheral using theses timer not working properly WHEN the POWER SAVE MODE were activated (in Master block).
  • 30/12/2010: v3.4
    • Input Capture : ICxMax value correspond to the max time defined including the margin (which is 10% by default)
  • 24/12/2010: V3.3c
  • 05/12/2010: v3.3b
  • 21/11/2010: v3.3a
  • 8/11/2010: V3.3
    • Corrected bug:
  • 23/07/2010: V3.2c
  • 31/03/2010: V3.2b
  • 28/03/2010: V3.2
  • 17/11/2009: V3.1
  • 26/09/2009: V3.0b
  • 26/09/2009: V3.0
    • change version numbering
  • 04/09/2009: V0.99h
  • 08/07/2009: V0.99g
  • 04/06/2009: V0.99f
  • 04/06/2009: V0.99e
  • 19/04/2009: V0.99d
  • 12/03/2009 V0.99c
  • 01/02/2009: V0.99b
    • added 4 chip...
  • 28/10/2008: V0.99a
