Release Notes
- 08/10/2011: v3.7
- Bugfix: Simulink model Error report were corrupted by the blockset. link (forum)
- Bugfix: Constant problem reported with older matlab (R2007b, perhaps affecting also R2008 and R2009... (forum))
- 11/09/2011: v3.6c
- 07/09/2011: v3.6b
- details comming soon
- 25/07/2011: v3.6
- Chip added : 256GP710A
- 15/05/2011: v3.5b
- 21/04/2011: v3.5
- 01/03/2011: v3.4c
- Examples updates
- 13/01/2011: v3.4b
- 30/12/2010: v3.4
- 24/12/2010: V3.3c
