DsPIC Block/Master
The dialog box parameters differs depending on which microcontroller is used.
Step Based on
PIC
59 Supported devices :
- On 30f family microcontroller
- The Instruction Per Seconds is automatically computed using the Quartz frequency provided. If you activate the PLL mulciplitcation, you have to enter the Desired Instruction Cycle Frequency. From the entered Desired Instruction Cycle Frequency and Clock source Frequency, the toolbox compute the compatible PLL multiplication which provides the closest Instruction Cycle Frequency.
Config Timer
Busy Flag Port
Busy Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
