Importing Simulink Generated Code into Mplab
Revision as of 18:40, 14 June 2008 by LubinKerhuel (talk | contribs)
MPLAB project with imported C files and library files (.a) previously generated with simulink
The model file is in the toolbox directory : examples\dsPIC_33f_Explorer16.mdl
Step 1 : Simulink
  • Compile the model
Step 2 : MPLAB
  1. Create a new project
  2. Select the target device (The same as defined in the simulink model : 33fJ256GP710)
  3. Select Language Toolsuite : Use the C30 Compiler ( free student version available on the microchip website)
  4. Import C sources files (from *Toolbox* \ examples \ dsPIC_33f_Explorer16_dspic \ Source )
  5. Import h source files (from *Toolbox* \ examples \ dsPIC_33f_Explorer16_dspic \ Source )
  6. Import Matlab library and PIC/dsPIC library : (all .a files in the *Toolbox*\examples\dsPIC_33f_Explorer16_dspic\Source directory ; The .a library corresponding to the PIC in the Microchip directory C:\Program Files\Microchip\MPLAB C30\lib for 24f pic, use the 24Fxxx file ( I use the coff version)
  7. Import Linker script file for the chosen PIC/dsPIC ; from the microchip directory : C:\Program Files\Microchip\MPLAB C30\support\gld
  8. Compile
Remarks
Know bug
I would not recommend to import C code files generated with simulink into MPLAB for the following reasons :
  • I is easier to maintain and improve code using simulink
  • Adding personnal C code can be easily done in simulink using the dsPIC block "call C function"
  • There should be no low level bug
  • High level debugging is easier in real-time, using MPLAB debugger usually add strange behaviour and make the debugging very hard.
