DsPIC Block
Revision as of 09:59, 15 June 2008 by LubinKerhuel (talk | contribs)
Root
- Master
- Select the targeted microcontroller, Set its Clock configuration including PLL, and few options to check that real time is respected.
- Compiler Configuration
- Define the size of double (32/64 bits ;default is 32)
Digital I/O
/Digital_Input /Digital_Output_Write /Digital_Output_Read
/ADC_Analog_to_Digital_Converter /Input_Capture /Output_Compare /Change_Notification /External_Interrupt_PWM /PWM_Motor_Output
/UART_Configuration /Tx_Output /Rx_Input /Tx_Output_Multiplexed_For_Matlab-Labview /Interface_Tx-Matlab
/SPI_Configuration /SPI_Input_Output
/CAN_Configuration /CAN_Transmit /CAN_Receive
/Calculus_Time_Step /C_Function_Call /Nop /Software_Reset
