Revision as of 19:00, 17 June 2008 by Mkerhuel (talk | contribs)
This fast prototyping tool for 16 bits PIC MCU :
Possible target are most of the dsPIC30f, dsPIC33, PIC24H and few PIC32. ( see detail on the download page) Supported Chip :
