DsPIC Block/UART Configuration
- 1 stop bit
- 8 bits data
- no parity
- no flow control
UART to be used
Main
Baud (kb/s)
Tx Rx Alternativ
TXEN
Gives following information : UxBRG register value. The real bit rate achieved by the microcontroller and the error in percent between the real bit rate and the requested bit rate. The max Byte/Step is the maximum number of byte that can physically be sent during one diagram time step. If your schematic send more data throw the UART, somme data will be lost or the real time constraint will be violated (ie, the time step will be longer than expected).
Tx Interrupt
Tx Interrupt take place
Tx Interrupt Priority
Tx Interrupt buffer size
Rx Interrupt
Rx Interrupt take place
Rx Interrupt Priority
Rx Interrupt buffer size
