Release Notes
Revision as of 20:25, 18 June 2008 by LubinKerhuel (talk | contribs)
    • Works with the last version of the Microchip dsPIC and PIC24 C compiler (v3.10) and with the PIC32 compiler (v1.02)
!! Updating your compiler is necessary !! (download from the microchip website)
Download the PIC / dsPIC Blockset for Simulink v3.7e (10 sep 2012) suporting Template:NbrChips chips.
compatible chips :
