Release Notes
Revision as of 23:36, 30 June 2008 by LubinKerhuel (talk | contribs) (revert chronology order)
compatible chips :
Few peripheral are available for the PIC32 : ADC, UART, Digital Input/Output. I wrote the driver for the Output Compare module but It still do not works. I am currently stuck on that point (If you get an idea why the Output Compare is never executed ...)
