Template:Languages
Revision as of 20:09, 27 July 2008 by LubinKerhuel (talk | contribs)
Template
Syntax
{{Languages|PageName}}
  • PageName (optional) - the name of the page to display language links for. If omitted then the English version of the current page is used. This parameter can normally be omitted, as it is only required if you want to link to a page other than the one you place the template on, which is very uncommon. If this parameter is used on a sub-page make sure you supply the root name, not the full page name (e.g. on MediaWiki/fr you would need to use {{Languages|MediaWiki}} and not {{Languages|MediaWiki/fr}}).
Usage
The template should only be placed on pages that exist in more than one language, and it should be placed in the same location on each translation of the page.
The English version of a page is always the main version, with all other languages as sub-pages, named using the appropriate language code (see below).
For example, on the Main Page you would include the text {{Languages}}, both on Main Page itself, and on each of its language sub-pages. The template automatically creates links to any language sub-pages that exist, e.g. Main Page/ja, Main Page/fr, and ignores non-existant languages.
See Project:Language policy for further details about translating pages.
Supported languages
This shows you the name of each language's sub-page (using Main Page as an example). Other languages may be added easily as necessary. Please use the appropriate prefix, as used on Wikipedia when adding a new language. Please do not add languages for which no pages exist yet, as this will increase the time needed to include the template without adding any benefit (languages are only displayed to the user when the relevant page exists).
The link on the language names goes to the Wikipedia in that language. If no Wikipedia in your language exists, do not add pages in that language to MediaWiki.org! This wiki is not the place for language advocacy - please go through the correct channels, and once your language has a Wikipedia then please return to add content here.
Page Name Language
Main Page English
Main Page/af Afrikaans
Main Page/ar Arabic
Main Page/az Azerbaijani
Main Page/bcc Southern Balochi
Main Page/bg Bulgarian
Main Page/br Breton
Main Page/ca Catalan
Main Page/cs Czech
Main Page/de German
Main Page/el Greek
Main Page/es Spanish
Main Page/fa Persian
Main Page/fi Finnish
Main Page/fr French
Main Page/gu Gujarati
Main Page/he Hebrew
Main Page/hu Hungarian
Main Page/id Indonesian
Main Page/it Italian
Main Page/ja Japanese
Main Page/ko Korean
Main Page/ksh Kölsch
Main Page/mr Marathi
Main Page/ms Malay
Main Page/nl Nederlands
Main Page/no Norwegian
Main Page/oc Occitan
Main Page/pl Polish
Main Page/pt Portugese
Main Page/ro Romanian
Main Page/ru Russian
Main Page/si Sinhalese
Main Page/sq Albanian
Main Page/sr Serbian
Main Page/sv Swedish
Main Page/th Thai
Main Page/tr Turkish
Main Page/uk Ukrainian
Main Page/vi Vietnamese
Main Page/yue Cantonese
Main Page/zh Chinese
Main Page/zh-hans Chinese (Simplified)
Main Page/zh-hant Chinese (Traditional)
Example
Here is how the language bar looks on the MediaWiki page:
