The atitude of the IMU system is estimated by fusing information from the rate gyros and the accelerometers.
After a short descripion of the electronics board, a method to log raw data from the sensors is presented. Simulink simulation relying on theses real data logged provides an easy way to tune and compare different calculation methods. The problem of atitude estimation using either rate gyro or accelerometers is settled. Three data fusing methods using both rate gyro and accelerometers are then described and compared :
- Method described by Pisano 2006 ?
Once tuned, one method is implemented in the embedded PIC or dsPIC microcontroller in no time with the one push button toolbox: the rapid prototyping tool described on this website (dsPIC blockset for Simulink).
Analysis of the Logged datas
5 files corresponding to 5 differents experiments are extracted using the script Extract_RawDatas.m.
Simulation based on real data
Non adaptative Kalman Filter
to be continued...
- M script
- Mat files
On-going projects
