Analysis of the Logged datas
5 files corresponding to 5 differents experiments are saved : 2 in static situation and 3 in dynamic situation where the IMU sensor board orientation is modified by a 90° rotation approximatly every 5 seconds. The script Caracterisation_Capteurs.m allow to plot the data analysis for each different experiments. Figures RawData and RawDataSpectre show the temporal and frequency plot of the experiment stored in the Simulink_Dynamic_Calibration3.mat file.
This experiment is a dynamic one; i.e with orientation changes. The temporal analysis show that the rate gyro y axis contains more noise than the rate gyro x axis. This may be due to a soldering problem (It was very hard to sold all theses parts with the very basic soldering stuff I have !) a problem due to the ADIS16080 part itself or to the powering of the accelerometer using the y rate gyro ref voltage. Anyway, The frequency analysis shows on the y rate gyro axis that this noise is contains within peaks frequency starting at 93Hz. As the gyro is integrated (i.e. low pass filtered) this high frequency noise has no influence on the angle estimation.
The frequency analysis also show that the accelerometers is perturbed by the 50Hz component that probably commes from the europe 50Hz general AC power. As the accelerometers is also low pass filtered, this high frequency noise has no influence on the estimated angle.
Simulation based on real data
Non adaptative Kalman Filter
to be continued...
- M script
- Mat files
On-going projects
