Revision as of 15:42, 20 August 2008 by LubinKerhuel (talk | contribs)
Log raw data from sensor
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Data fusion algorithms
Simulation with real data
  • The high pass filter is:
\frac{1}{s} * \frac{s^2}{(s+0.2)^2} = \frac{s}{(s+0.2)^2}</Tex>
Non adaptative Kalman Filter
This method gives results similar to the 2nd order complementary filter with the advantage of also providing directly the gyro bias estimation and the unbiased angular rate of the system. Calculation are not much complicated.
to be continued...
IMU_for_dsPIC.zip : All Simulink and Matlab file used with data logged. Will be updated soon
  • Simulink models
    • IMU_Simulation.mdl
  • M script
    • Extract_RawDatas.m
    • Script_Kalman.m
  • Mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
-Old data
