Revision as of 22:29, 23 December 2008 by LubinKerhuel (talk | contribs)
Implementation of a miniature Inertial Measurement Unit (IMU) on a microcontroller (dsPIC) using rapid prototyping tools. Simulink is used for both simulate and implement calculation onboard the microcontroller. This IMU estimates its pitch and roll angle based on inertial MEMS sensors.
One rate gyro (ADIS 16080) with the basic material used for soldering. Tiny wires used are extracted from a washing machine motor’s coil.
The micro Inertial Measurement Unit (IMU) It is an Attitude indicator (ADI) or gyro horizon also called artificial horizon that estimates its attitude about the two axis: pitch and roll. The three main electronics parts are:
  • Rate gyros measuring roll, pitch and yaw (with 6DoF sensor board only) speed rate
The inherent problem of atitude estimation using MEMs is then settled. Then, a first IMU based on a 5 DoF is described. The electronics sensor board is described, Methods to log data is presented. Different data fusing algorithms are then compared with simulation relying on real data logged with the presented sensor board. The implementation of the simulink model using a dsPIC is then described. I am using the rapid prototyping tool described on this website (dsPIC blockset for Simulink) allowing generating the .hex code file for the microcontroller directly from the simulink model file with a one push button procedure. Real time constraints are analyzed and fixed point implementation is considered.
IMU based on 5 DoF sensor board do not take into account angles coupling. This problem is described and an IMU based on an extended 6 DoF board is presented.
IMU based on a 5 DoF sensor board (2 gyro, 3 accelero)
The Embedded IMU Schematic is equipped with one three axis accelerometer MMA7260QT coupled with two one axis rate gyro ADIS16080 (see fig:IMU_SensorSchematic). This custom made board may be replaced by a commercial one like the SEN-00741 from Sparkfun called IMU 5 Degrees of Freedom.
The overall sensor card is supplied with a single stabilized 5V. The 2.5V alimentation required by the accelerometer is provided by the 2.5V Voltage Reference of one gyro. The low current requirement for the accelerometers does not perturb the rate gyro. Each rate gyro has two unused analog input. Thus, the two gyros have 4 analog input, 3 of which are used to convert the three analog values ax, ay, and az from the accelerometer. This sensor board transmits the 5 data (3 acceleration + 2 rate gyros) to the microcontroller through its digital SPI bus.
Log raw data from the 6 DoF sensor board
  • model time-step is 1ms
IMU_dsPIC_30f4012_TestElectronics Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the values from the X, Y and Z axis of the accelerometer, and the Y and X axis of the rate gyro. Data are sent to Matlab (or labview) through the UART at 115200bps with the Tx Output Multiplexed for Matlab-Labview block. All data cannot be send ; there will be missing data thus this model is useful to check every component is working only.
 >> datas = [T R]';
 >> save mydatafile datas;
Data fusion algorithms
Simulation with real data
  • The high pass filter is:
State Space Approach
The non adaptative Kalman filter tracks the rate gyro bias and estimate the angle by integrating the unbiased gyro.
Implementation on a dsPIC
Complementary Filter Order 1
This model implements the complementary filter on the dsPIC and sends the result to matlab. It has the same behaviours as the simulated filter.
The estimated angle using accelerometers (blue curve) is quite noisy. However, it steady value is correct. The estimated angle relying on the integration of the gyro is clean but drift (red curve). Note that the dsPIC has just been switch on and the High pass filter of the pseudo integrator of the gyro has not yet removed the remaining DC bias of the gyro. The DC bias of the Gyro has probably changed due to non constant temperature. Thus, the integrated angle drifts slowly from its real value. The green curves that use both data is clean and drift free. Its dynamics is as fast as the gyro dynamic. Note that at the beginning, the High pass filter (with a higher bandwidth than the gyro pseudo-integrator high pass filter) has not yet removed the gyro bias. However, at the end of the animation (11 seconds long: from 3, 5 to 14, 5), both curves (blue and green) are merging as in the simulation.
The IMU_ComplementaryFilter simulink model is a 'copy-past' mixture made of the IMU_LogData 'data management' part with the IMU_simu_RealData model tuned and optimize filter. This model implements the complementary filter on the dsPIC and sends the result to matlab. It will have the same behaviours of the simulated filter.
Fixed point
  • Simulink models
    • IMU_Simulation.mdl
    • IMU_Simulation_FxdPts.mdl
  • m script
    • Extract_RawDatas.m
    • Script_Kalman.m
    • Caracterisation_Capteurs.m
  • mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
IMU based on a 6 DoF sensor board (3 gyro, 3 accelero)
One rate gyro has been added on the sensor presented above to measure the yaw rate.
  • Problem of logging data is now different
  • the two gyro gain change (unexpected!)
  • data analysis
State space approach with non linearity
  • biais analysis is different : develop (do not use magnetic field)
On-going projects
I am planning to use this IMU in an autopilot for remote controlled glider ( as previous project described on my french website : http://lubink.free.fr)
Point to clarify, error, remarks ? Please, leave your comment on the forum!
