Explorer 16 Board
- One led (Port A7) :
Set UP
Simulink
PIC
Open the Master block.
Set up PIC peripheral
UART
Functions
Blinking Leds
Filtering
| dsPIC 33FJ256GP710 | 24JF128GA010 |
| [Report] | [Report] |
| [Hex file] | [Hex file] |
Log and Plot Data
Pic side
Computer side
Enable comment auto-refresher
