Importing Simulink Generated Code into Mplab
Revision as of 10:59, 25 April 2010 by LubinKerhuel (talk | contribs)
MPLAB project with imported C files and library files (.a) previously generated with simulink
The model file is in the toolbox directory : examples\dsPIC_33f_Explorer16.mdl
Step 1 : Simulink
  • Compile the model
Step 2 : MPLAB
  1. Create a new project
  2. Select the target device (The same as defined in the simulink model : 33fJ256GP710)
  3. Select Language Toolsuite : Use the C30 Compiler ( free student version available on the microchip website)
  4. Import C sources files (from *Toolbox* \ examples \ dsPIC_33f_Explorer16_dspic \ Source )
  5. Import h source files (from *Toolbox* \ examples \ dsPIC_33f_Explorer16_dspic \ Source )
  6. Import Matlab library and PIC/dsPIC library : (all .a files in the *Toolbox*\examples\dsPIC_33f_Explorer16_dspic\Source directory ; The .a library corresponding to the PIC in the Microchip directory C:\Program Files\Microchip\MPLAB C30\lib for 24f pic, use the 24Fxxx file ( I use the coff version)
  7. Import Linker script file for the chosen PIC/dsPIC ; from the microchip directory : C:\Program Files\Microchip\MPLAB C30\support\gld
  8. Compile
Remarks
Know bug
I would not recommend to import C code files generated with simulink into MPLAB for the following reasons :
  • I is easier to maintain and improve code using simulink
  • Adding personnal C code can be easily done in simulink using the dsPIC block "call C function"
  • There should be no low level bug
  • High level debugging is easier in real-time, using MPLAB debugger usually add strange behaviour and make the debugging very hard.
Add your comment
Lubin KERHUEL website welcomes all comments. If you do not want to be anonymous, register or log in. It is free.
