Case Study: Position Control of DC Motor
Revision as of 03:12, 4 February 2009 by LubinKerhuel (talk | contribs)
Problem:
Original Model
Subsysteme1
pid
This is one of the first projects I made. I am trying to control a DC servomotor with incremental encoder (FAULHABER 1717V0023 this is the link: http://micromo.com/servlet/com.itmr.waw.servlet.Anzeige?fremdaufruf=ja&kdid=40929&sprachid=1&htdigurl=/n112053/i404618.html ). The purpose is place a load on the end of a bar attached to the motor shaft and the motor must keep steadily with no move at all. The motor must stay firm as shown in the drawing attached. So if I change the mass of the load or if I unload the bar, the motor has to stay immobile. This is the model and the C file I am using in a dsPIC30F4012. It seems to work fine, but sometimes when I am pushing or pulling the bar the motor lose control and start running wildly. Can you please tell me if my design is correct, or if I am not considering something important? Why the motor gets crazy?
Possible problems
controller design
PID controller
Overflow
tricks
Saturation followed by abs
set the negative saturation at 0 directly
