DsPIC Block/Output Compare HW
Outline
The Output Compare Hardware (OC_HW) block generates PWM impulse on the Output Compare peripheral. This driver does not use any software, in comparison with Block/Output_Compare PWM Output Compare block that use software interrupt. The two improvements (compared to Block/Output_Compare PWM Output Compare block) are:
Drawbacks (compared to Block/Output_Compare PWM Output Compare block) are:
- Time Up and Period
- Time Down and Period
- Time Set and Reset
Up or Down or Periode = <tex>T_{set} * \frac{OCmax}{MaxChannel}</tex>
With
Output Channels
Channels Input Type
Periode as block input
Period Max
