Hyper Sampling
Revision as of 17:16, 1 March 2009 by LubinKerhuel (talk | contribs)
RC filter
The Electronics – RC filter
Principle
The filter output signal is
  • Periodic
  • Time invariant
Simulink model file
Results
Looking deeper
Acknoledgement
Logging Animation
