Review
Tools
Microchip
Microchip released a first version of a blockst in late 2008 (about november). The version 2 of the microchip blockset were released on June, 5th 2009. This second version seems more interresting as seems more similar to the blockst I developped (*). Anyway, interrupt seems not to be handeled properly to makes the peripheral works efficiently. A free evaluation version is available from their website. Please report your feeling on the forum.
(*) Strange facts: In microchip dsPIC_mrmain.tlc file in directory dspicblks, you can find
%if (CalculusTimeStepEN == 1)
CalculusTimeStep = TMR1;
%endif
%if (MasterBusyPort != -1)
The same instructions can be found in the original: In Lubin's blockset, dsPIC_mrmain.tlc file in directory blocks
if (_T1IF) CalculusTimeStep = PR1; /* Overload */
else CalculusTimeStep = TMR1;
%endif
This code is a very specific function that can only be found in the "Lubin's blockset". This code remains in their tool, even in V2 published on 5th 2009 despite this file is not used anymore. There are probably other example, but nevermind, I do not understand what's happening there. (I now scramble tlc files, thus, you will find variables name : CalculusTimeStepEN and CalculusTimeStep)
I strongly encourage Microchip to find many new ideas to make dsPIC programming easier and even more exciting with Simulink. But I would be disapointed if Microchip blockest is only a not finished copy, of tools already existing.
A workaround to remove the 30s pause : create a new m file called pause.m in the same directory as the model being compiled with the following text :
function pause(a)
Quantiphi
Scicos-Scilab
Embedded Target for dsPIC
(Matlab Blockset from this website)
Supported chip :
Experimentation
