Review
Tools
Microchip
Microchip released a first version of a blockst in late 2008 (about november). The version 2 of the microchip blockset were released on June, 5th 2009. It seems that The Dev Team get inspired from an old version of my blockset (*). Anyway, with this blockset, you have to configure all registers of the peripheral. This it not really convenient. I also did not see efficient interrupt handling to make some peripheral works. A free evaluation version is available from their website. Please try it and report your impressions.
3 simple steps to remove the 30s pause from microchip free evaluation version :
- Remove/Rename the file ./Microchip/MPLAB IDE/Tools/MATLAB/dsPIC_Matlab/dspic/serKeyVal.p (renamed in serKeyVal.old)
- create a new m file in the same directory
function a = serKeyVal()
disp('Hello Word')
a=0;
- save as serKeyVal.m
(*) speicfic parts of code from my blockset can be found in microchip blockset (but that's not official !): In microchip dsPIC_mrmain.tlc file in directory dspicblks, you can find
%if (CalculusTimeStepEN == 1)
CalculusTimeStep = TMR1;
%endif
%if (MasterBusyPort != -1)
Sames instructions in the original: In Lubin's blockset, dsPIC_mrmain.tlc file in directory blocks
if (_T1IF) CalculusTimeStep = PR1; /* Overload */
else CalculusTimeStep = TMR1;
%endif
This code is a very specific function that can only be found in the "Lubin's blockset" (not accessible in the microchip blockset). This code remains in Microchip blockset, even in V2 published on 5th 2009. There are probably other similar part of code.
(I now scramble tlc files so as to avoid non-official collaboration. Thus, you will recognize variables name : CalculusTimeStepEN and CalculusTimeStep in my tlc file.)
Quantiphi
Scicos-Scilab
Embedded Target for dsPIC
v3.7e (10 sep 2012) suporting 100
Experimentation
