DsPIC Block/ADC Analog to Digital Converter
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/ADC Analog to Digital Converter to DsPIC Block/ADC Analog to Digital Converter: Block is a special page, creates many issues)
Block Analog to Digital Converter
Analog to Digital Converter Dialog
Type
Mode
  • Continuous Sampling and get last channel value : In this mode, all selected channel are continuously scanned and converted at high speed. When the simulink block outputs are read, the last value converted from each channel is used. This method provide the minimum time lag between the end of conversions and the calculations using theses values.
  • Continuous Sampling get output vector : In this mode, all channel selected are scanned and converted at low speed allowing to get exactly the number of sample defined in 1 time step. For example, you can get 6 samples from both channels AN0 and AN1. The samples of AN0 (resp AN1) will have a fixed sample rate. To avoid missalignment between end of time step and sampling rate, considere using ADC as timer refference in the master block. In this case, the time step is triggered by the end of the ADC conversions.
Voltage Reference
Output Format
Interrupt Priority
AN Channel to convert
Max Value ANmax
External Input Resistor
Temperature °C
Provides the following informations :
  • Tsmp : Time to sample 1 channel
  • T/Channel : Time of sample and convert 1 channel
  • Tall : Conversion time for all samples
Trigger Source
  • auto convert (default)
  • Motor Control PWM
  • Timer3 (OC_HW PWM)
  • Low to High transition on INT0 pin
