DsPIC Block/Input Capture
Interrupt Priority
Input Channels
Channels Input Type
- 3 : is to get both High and low pulse duration
- 4 : is to get the periode using rising edge
- 8 : is to get the periode using falling edge
- 5 : is to get both High pulse duration and periode using rising edge
- 10 : is to get both Down pulse duration and periode using falling edge
Max/Channels
Define max time in secondes of the largest event tu be measure by the respective channel. Safety margin in %
Changed Detected on
Add a boolean outputs to the block. This output take the value 1 if a changed has occured since last block execution. The output can be set to 1 either at rising edge, falling edge or both edges.
