DsPIC Block/Change Notification
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Change Notification to DsPIC Block/Change Notification: Block is a special page, creates many issues)
Block Change Notification
The Change Notification (CN) block allow to detect a change on one or several inputs. This peripheral can also be used to measure the duration of a pulse (like PWM) on all CN ports of dsPIC / PIC24. Note that this block used in PWM input mode is less robust than Input Capture peripheral.
Change Notification Dialog
Input Channel
Specify Change Notification channel(s) (CN) starting from 1. Specify multiple channels as a vector. This will also set the block's number of output.
Channel Input Type
  • 1 : get the High pulse duration
  • 2 : get the Low pulse duration
  • 3 : get both High and low pulse duration
  • 4 : get the periode using rising edge
  • 8 : get the periode using falling edge
  • 5 : get both High pulse duration and periode using rising edge
  • 10 : get both Down pulse duration and periode using falling edge
  • The position value in the vector refers to corresponding channel defined in "Input Channels".
Max/Channels
Safety Margin in %
Change Detected on
Pull up
for each channel, 1 mean internal Pul-up resistor connected ; 0 mean Pull up not disconnected.
