DsPIC Block/Rx Input
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Rx Input to DsPIC Block/Rx Input: Block is a special page, creates many issues)
Block UART Rx Input
If no bytes have been received, the output is set to the default value. The block can be a blocking function : stop the step execution until one byte is received ( not recommended due to possible real-time constraint violation).
UART Rx Dialog
UART Used
-1 for inherited
Blocking Function
Output Default
Received Output Flag
  • 1 if one byte has been received,
  • 0 if no data has been received ; the output value is the "Output Default" value.
