DsPIC Block/Interface Tx-Matlab
Interface PIC-Matlab
R, T_R, Rn and T_Rn are accessible from the workspace. R and Rn matrix contains NaN values. The function padr allow to remove NaN values.
The Rn matrix is a subset of the R matrix. Rn contain the last 10000 values of R. Name and size of both matrix can midified. Rn is a smaller matrix that may be used for real time plotting on slow system.
The central text box contain the command that are interpreted iteratively with time delay configurable (0.2 seconds here). Any matalb command can be used. It is also possible to call a matlab script file. The four buttons on top: Default, Dflt signe, Simulink, Emission are four example of script. The default script plot unsigned data. Dflt signe plots signed int16 data.
Long log: When large log are required (for example, 10 min with constant flow data from the UART), increasing the max size of the buffer (matrix R) may not work at the constant matrix size increase (until it reach the max size defined) may slow down the computer and causing data lost. The method is to keep R and Rn small and to log directly the upcomming raw data with the buttons Log.txt / Ren / Load and Delete button.
For all theses button, it may be necessary to click several time (alternatively, you can increase the delay value at the bottom of the interface.
Log.txt : Start a logging raw data in the file Log.txt. The value below the button is the number of characters logged. If stopped and started again, value are concatenated into the file.
Ren : Rename the raw data file Log.txt with a name containing current date and time. This button may be pressed during a log, or after it has been stopped with the first button (which is renamed as Stop)
Load : Choose and load one (or many) raw data file (txt file stored), decode the raw data file into a workspace variable Rn that can be traced with the Plot Buffer button (that execute the text box script). Data are also stored into a .mat file with the same name as the txt file. Variable stored in the mat file is Rn which is renamed into Rtotal.
Delete : Delete the file Log.txt (can be pressed during a log, reseting thus the log).
Real-Time Consideration
- real time : http://www.kerhuel.eu/forum/viewtopic.php?f=1&t=207&p=787
- real work : research papers
