DsPIC Block/SPI Configuration
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/SPI Configuration to DsPIC Block/SPI Configuration: Block is a special page, creates many issues)
Block SPI Configuration
SPI Configuration Dialog
n° SPI
SPI used
Mode
Master or Slave : define who is driving the clock signal
Prescaler
SDO Enable
Data length
Slave Select Pin Enable
Sample phase
Clock Active State
Output change on transition
