Flex Board Blinking Led
Revision as of 07:31, 1 September 2010 by LubinKerhuel (talk | contribs)
Flex Board equiped with a dsPIC33Fj256MC710, from Evidence Srl
Model Configuration
Simple Model for the Flex Board (download the model)
UART is configured with its maximum speed (for the PC) i.e. 115200 bauds. This UART speed cannot be achieved without enabling the dsPIC clock multiplier PLL. Without PLL, the microcontroller run at 2MIPS and the UART speed error (read from the UART configuration block) is of 8.5%. Therefore, PLL is activated. The targeted speed must be compatible with the UART baud used. With a configuration of 9.2MIPS, UART has a speed error of -0.17% (The real baud is 115000 ; error is : [math]\frac{115000 - 115200}{115200} = -0.0017[/math])
Matlab Graphical User Interface to send and log data to and from the Flex Board
Sinus with variable amplitude logged from the Flex Board throught UART
  • the variable 60 set the amplitude of the sinus generated.
  • the variable 61 define which data is send to the PC :
    • if 0, the Time Step is being sent
    • if 1, the Sinus is being sent.
  • the variable 62 is directly sent to the PC
Time Step. From the Master block, the 2ms time step correspond to a value of 18399. Real time constraints are respected.
It is quite time consuming but this model could be optimized. Generation of the sinus should be done using a look up table (from the simulink standard library) and all calculation should be done using only fixed step variable (no double !)
