CAN communication between two dsPIC
Revision as of 23:36, 30 December 2010 by LubinKerhuel (talk | contribs) (Created page with "=Description= The objective of this example is to demonstrate how to use the can peripheral embedded on some dsPIC. Two dsPIC exchanges numerical data through the CAN bus. Both ...")
Description
The objective of this example is to demonstrate how to use the can peripheral embedded on some dsPIC. Two dsPIC exchanges numerical data through the CAN bus. Both microcontrollers (here, two dsPIC 30f4012) are programmed using the dsPIC blockset for simulink available on this website. This example was added in the blockset version 3.4.
Next to come...
