DsPIC Block
Revision as of 11:23, 25 April 2010 by LubinKerhuel (talk | contribs)
Root
Master
Select the targeted microcontroller, Set its Clock configuration (Quartz or External Clock, PLL...), and few options allowing to check that real time time step constraint is respected.
Compiler Configuration
set the size of double data type (32 or 64 bits ; default is 32)
Digital I/O
Digital Input
Logic Input
Digital Output Write
Logic Output, write a value
Digital Output Read
Peripheral I/O Functions
Input Capture (IC)
Change Notification (CN)
External Interrupt (EI)
Output Compare (OC)
Output Compare Hardware (OC_HW)
Pulse width modulation (PWM) signal generation without interrupt, allow fast PWM and synchronisation with ADC
PWM Motor Output
Serial Port (UART)
UART Configuration
Set UART configuration
Tx Output
Rx Input
Interface Tx-Matlab
MAtalb Grapical User Interface to collect, view and record varaible evolution send using Tx Output Multiplexed for Matlab-Labview
SPI PORT functions
SPI Configuration
Configure the microcontroller SPI port
SPI Input/Output
Input-Output driver for SPI
SPI Input/Output interrupt driven
Input-Output interrupt driven SPI driver
BUS CAN
CAN Configuration
Configure the CAN Peripheral
CAN Transmit
CAN Receive
BUS I2C
I2C Master
I2C Peripheral (as master)
Others
Calculus Time Step
Chronograph
Get time within the time step
C Function Call
Call custom write handed C function
Nop
Add Nop instructions introducint a lag time between two blocks
Software Reset
Reset the microcontroller
