Revision as of 01:18, 14 February 2011 by LubinKerhuel (talk | contribs)
File:Scope HM205 PWM 01.png
Scope picture of a PWM Signal with a large duty cycle
File:Scope HM205 PWM 02.png
Scope picture of a PWM Signal with a small duty cycle
Description
PWM Circuit
Bootloader
Simulink models
Common parts
Master block
Bootloader RESET
Model (A): Emission
Sine wave generation
Measuring Time Step
PWM Generation
Model B: Reception
Simulink model A: PWM_b_30f4012
