Revision as of 01:58, 14 February 2011 by LubinKerhuel (talk | contribs)
Description
Scope picture of a PWM Signal generated by the microcontroller (A), here a large duty cycle code for a large value
Scope picture of a PWM Signal generated by the microcontroller (A), here a small duty cycle code a small value
PWM Circuit
Bootloader
Simulink models
Common parts
Master block
Bootloader RESET
Bootloader Reset subsystem. The subsystem read one value received on the UART. If it receive the value 55, another subsystem is enabled. This subsystem will block the step until a character 66 is received on the UART, causing a reset of the chip (see subsystems).
Model (A): Emission
Sine wave generation
Measuring Time Step
PWM Generation
Model B: Reception
