Picooz
Revision as of 23:17, 15 March 2011 by LubinKerhuel (talk | contribs)
Miniature flying helicopter Picooz from Silverlit
  • One Picooz
  • One Atlas
They are built by Silverlit
Picooz
Inside a Picooz, different part with their respective weight
Weight
  • EPP : 1.57g
  • Main propeller + main rotor + support : 4.55g
  • accumulator : 1.87g
  • Electronic board : 0.85g
  • tail propeller : 0.08g
  • tail motor : 0.63g
  • tail motor housing : 0.17g
  • tail main bar : 0.37g
  • tail paper : 0.02g
  • tail thin bar at the end : not measured but very small
  • Total (Original Picooz measurement) : 10.40g
main rotor force
Tail rotor force
Accumulator
Onboard electronic
Before and after disassembling. these two versions fly successfully
  • controlling the main rotor and the tail propeller.
  • demodulating the IR from the remote control
Atlas
Sky Cruiser (NIKKO)
brand new helicopter weight: 23.97g
