Release Notes
- 21/04/2011: v3.5
- Suport for multi tasking added
- MPLAB project created has now relative path. Few bugs corrected
- 01/03/2011: v3.4c
- Examples updates
- 13/01/2011: v3.4b
- 30/12/2010: v3.4
- 24/12/2010: V3.3c
