Release Notes
- 25/07/2011: v3.6
- Chip added : 256GP710A
- 15/05/2011: v3.5b
- 21/04/2011: v3.5
- 01/03/2011: v3.4c
- Examples updates
- 13/01/2011: v3.4b
- 30/12/2010: v3.4
- 24/12/2010: V3.3c
