DsPIC Block
Revision as of 10:21, 15 June 2008 by LubinKerhuel (talk | contribs)
Root
Master
Select the targeted microcontroller, Set its Clock configuration including PLL, and few options to check that real time is respected.
Compiler Configuration
Define the size of double (32/64 bits ;default is 32)
Digital I/O
Digital Input
Logic Input
Digital Output Write
Logic Output, write a value
Digital Output Read
Peripheral I/O Functions
Input Capture (IC)
Change Notification (CN)
External Interrupt (EI)
Output Compare (OC)
PWM Motor Output
Serial Port (UART)
UART Configuration
Set UART configuration
Tx Output
Tx Input
Interface Tx-Matlab
MAtalb Grapical User Interface to collect, view and record varaible evolution send using Tx Output Multiplexed for Matlab-Labview
SPI PORT functions
SPI Configuration
Configure the microcontroller SPI port
SPI Input/Output
Input-Output driver for SPI transmission
BUS CAN
CAN Configuration
Configure the CAN Peripheral
CAN Transmit
CAN Receive
BUS I2C
I2C MAster
I2C Peripheral (as master)
Others
Calculus Time Step
Get the calculation time
C Function Call
Call custom write handed C function
Nop
Add Nop instructions introducint a lag time between two blocks
Software Reset
Reset the microcontroller
