DsPIC Block/Digital Input
< DsPIC Block
Revision as of 19:16, 26 May 2008 by 139.124.74.228 (talk) (New page: The Digtal Input block reads the logical value previously writen on the microcontroller pin. =Dialog Box Parameters= ==Port== * Port used ==Pin== * Pin used, start at 0 and is defined i...)
Port
- Port used
Pin
- Pin used, start at 0 and is defined in vector form allowing several Pin to be read at the same time.
- -1 is inherited
