Revision as of 11:11, 20 August 2008 by LubinKerhuel (talk | contribs)
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Analysis of the Logged datas
5 files corresponding to 5 differents experiments are saved. Figure:RawData shows the result of a logged data. Figure:RawDataSpectre shows the spectral analysis of the same
Simulation based on real data
Non adaptative Kalman Filter
to be continued...
  • Simulink models
    • IMU_Simulation.mdl
  • M script
    • Extract_RawDatas.m
    • Script_Kalman.m
  • Mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
