Log raw data from sensor
Data fusion algorithms
Simulation with real data
- The high pass filter is:
Non adaptative Kalman Filter
Implementation on a dsPIC
Complementary Filter Order 1
Non-adaptative Kalman Filter
Not described yet
Fixed point
Fixed point version id working and can be downloaded in the .zip file at the bottom of the page. Description of the fixed point algorithm will be added here.
IMU_for_dsPIC.zip : All Simulink and Matlab file used with data logged. (updated on 14 september 2008)
- IMU_Simulation_FxdPts.mdl (just added)
- IMU_dsPIC_30f4012_AlphaBetaFilter_20Mips_FixedPoints.mdl (just added)
- m script
- Caracterisation_Capteurs.m
- mat files
On-going projects
