Picooz
Revision as of 00:50, 19 January 2009 by LubinKerhuel (talk | contribs)
Miniature flying helicopter Picooz from Silverlit
  • One Picooz
  • One Atlas
Picooz
Inside a Picooz, different part with their respective weight
main rotor force
Tail rotor force
Accumulator
Onboard electronic
Before and after disassembling. These two version fly successfully
The tiny electronic board has two functions :
  • controlling the main rotor and the tail propeller.
  • demodulating the IR from the remote control
Weight
  • EPP : 1.57g
  • Main propeller + main rotor + suport : 4.55g
  • accumulator : 1.87g
  • Electronic board : 0.85g
  • tail propeller : 0.08g
  • tail motor : 0.63g
  • tal motor housing : 0.17g
  • tail main bar : 0.37g
  • tail paper : 0.02g
  • tail thin bar at the end : not measured but very small
  • Total (Original Picooz measurement) : 10.40g
Atlas
