DsPIC Block/UART Configuration
- 1 stop bit
- 8 bits data
- no parity
- no flow control
UART to be used
Main
Baud (kb/s)
Tx Rx Alternativ
TXEN
Tx Interrupt
Tx Interrupt take place
Tx Interrupt Priority
Tx Interrupt buffer size
Rx Interrupt
Rx Interrupt take place
Rx Interrupt Priority
Rx Interrupt buffer size
