DsPIC Block/SPI Input Output
< DsPIC Block
Revision as of 21:45, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: Input-Output Driver for SPI module The SPI Input-Output block can be configured as an input for SPI data, as an SPI output, or as both Input-Output. The SPI pin can be disabled after read...)
n° SPI
SPI used
SPI Input
SPI Output
Special SPI
Allow to disable SPI pin function and to use theses pin as digital input/output. The choices are :
  • Always Enable
  • Disable After block execution
  • Re-Enable before block execution
  • Re-Enable Execute and disable
Data Length
block execution of other blocks while no data are received
