DsPIC Block/CAN Receive
< DsPIC Block
Revision as of 21:54, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: Read data from a CAN bus The CAN Receive block with selected Identifier. The CAN message contain between 1 and 8 bytes. The five filters defined which message Identifier will be keept. Me...)
Num CAN
Filter 0 and 1 Acceptance Mask / Filter 2, 3 and 4 Acceptance Mask
Message x Data Length
Acceptance Filter x
Acceptance Filter type
  • Standard or Extended
  • Standard 11 bits
  • Extended 29 bits
Output received Data Length
Output Flag New Message
Output Identifier
Output Flag Data Request To send
Receive Error Counter
Output Flag Data Lost
Information
