DsPIC Block/I2C Master
< DsPIC Block
Revision as of 21:58, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: Input driver for I2C Peripheral Provide acces to the I2C peripheral of the dsPIC (when available). The I2C bus sequence depends on the component being addressed. This sequence is configur...)
Ref I2C
Sequence Specify the I2C bus sequence. The sequence is enterred as text, between single quote 'xxx'.
  • S : generate a start condition on the bus
  • Sr : generate a re-start condition on the bus
  • P : generate a stop condition on the bus
  • A and Axxx : send the address of the component of the bus. If followed by a decimal number (like A104) this number is taken as the address. Otherwise, a block input appear noted A1
  • W and Wxxx : write a data of type uint8 on the bus. If followed by a decimal number (like W82) this number is taken as the data being written. Otherwise, a block input noted W1 appears.
  • R and Rnack : Read a data of type uint8 on the bus. R generate an acknowledge. Rnack do not generate the acknowledge. A block output noted R1, R2 ... Rn appears for each R or Rnack present in the sequence.
Example of sequence : ' S A125 W R R P '
Initialisation
Define when the I2C peripheral is configured :
  • When PIC is initialized (only once)
  • When I2C bus is enable (if Enable I2C is checked)
  • Both
  • None
I2C bus frequency
Slew rate active
Activate Slew rate
Enable SMB bus threshold
Output Error flag
