| Languages: |
{{#widget:Vimeo|id=6481193}}
When programming a microcontroller, a lot of time is usually spent on peripheral configuration and on real time problems like sampling rate, multitasking... This blockset gives you the possibility to get ride of these tasks and to concentrate only on the math part (control, filter, logic ...) of the Simulink model. You can simulate the model that will be implemented into the microcontroller. You do not need much knowledge about PIC/dsPIC programming. The blockset support most peripheral present on the microcontroller and configure automatically these peripherals selected (configure also timers and model time step).
Supported Chip :
