Release Notes
Revision as of 11:13, 2 October 2009 by LubinKerhuel (talk | contribs)
Supported microcontroller :
  • 26/09/2009: V3.0b
    • demo Version V3.0 had a limitation that (will) make it not workable from October 17th 2009
  • 26/09/2009: V3.0
    • change version numbering
  • 04/09/2009: V0.99h
  • 08/07/2009: V0.99g
  • 04/06/2009: V0.99f
  • 04/06/2009: V0.99e
  • 19/04/2009: V0.99d
  • 12/03/2009 V0.99c
  • 01/02/2009: V0.99b
    • added 4 chip...
  • 28/10/2008: V0.99a
