DsPIC Block/Master
Illustration not up to date !
Step Based on
PIC
59 Supported devices : 24fJ128GA006, 24fJ128GA008, 24fJ128GA010, 24fJ64GA006, 24fJ64GA008, 24fJ64GA010, 24fJ96GA006, 24fJ96GA008, 24fJ96GA010, 30f2010, 30f2011, 30f2012, 30f3010, 30f3011, 30f3012, 30f3013, 30f3014, 30f4011, 30f4012, 30f4013, 30f5011, 30f5013, 30f5015, 30f5016, 30f6010A, 30f6011, 30f6012, 30f6013, 30f6014, 30f6015, 32MX360F512L, 32MX460F512L, 33fJ128GP206, 33fJ128GP306, 33fJ128GP310, 33fJ128GP706, 33fJ128GP708, 33fJ128GP710, 33fJ128MC506, 33fJ128MC510, 33fJ128MC706, 33fJ128MC708, 33fJ128MC710, 33fJ256GP506, 33fJ256GP510, 33fJ256GP710, 33fJ256MC510, 33fJ256MC710, 33fJ64GP206, 33fJ64GP306, 33fJ64GP310, 33fJ64GP706, 33fJ64GP708, 33fJ64GP710, 33fJ64MC506, 33fJ64MC508, 33fJ64MC510, 33fJ64MC706, 33fJ64MC710
Instruction Cycle Frequency
Config Timer
Busy Flag Port
Busy Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
