Template:Documentation/core
< Template:Documentation
Revision as of 21:42, 30 August 2010 by LubinKerhuel (talk | contribs) (Created page with "<!-- Start of green doc box --><div id="template-documentation" class="template-documentation iezoomfix"><!-- Add the heading at the top of the doc box: -->{{#ifeq: {{{headin...")
  1. if: yes Template documentation
}} This is the {{documentation/core}} sub-template.
Do not use this template directly, use {{documentation}} instead.
{{documentation}} calls {{documentation/core2}} which in turn calls this template. This template holds most of the code for {{documentation}}, while {{documentation}} and {{documentation/core2}} do parameter preprocessing. Thus simplifying the code.
Technical details
This sub-template currently expects these parameters:
| heading = {{{heading|¬}}}   <!--Note that the "¬" is necessary
     so we can detect the difference between empty and undefined-->
| heading-style = {{{heading-style|}}}
| content = {{{content|}}}    <!--Text instead of a /doc page-->
| link box = {{{link box|}}}  <!--So "link box=off" works-->
| docpage =     <!--Full pagename of the doc page-->
| doc exist =   <!--"yes" if the doc page exists, empty string if not-->
| docname fed = <!--"yes" if a docname was manually fed-->
| sandbox =     <!--Full pagename of the /sandbox-->
| testcases =   <!--Full pagename of the /testcases-->
| template page =   <!--Full pagename where the {{documentation}}
    template is placed, but without ending /sandbox or /testcases.
    Note: Unfortunately might not be the "correct" namespace if
    the template is in subject space and the {{documentation}}
    template is in talk space or the other way around.-->
For more documentation see {{documentation}}. pt:Predefinição:Documentation/core
